HSF for hot / humid climate
srs
111
I will be buying an atholnxp 1600 and need a HSF for it. It will be in a hot / humid climate with probably no ac. Any recommandations ? Will the HSF that comes with the retail box suffice or should I spend extra ?
thanks
neutralizer
11,552
depends on what kind of noise u can tolerate. i can stand my thermaltake volcano 6 cu, but i can't stand my friend's swiftech.
John
Moderator Emeritus<br>Elite Member
4
Retail hsf will work just fine. I would not use it if you plan on overclocking though.
srs
111
there will be no overclocking, and the quieter the better
what worries me is the lack of air conditioning
