HS&F bracket replacement
Redviffer
Looking for replacement parts for socket 478 motherboard, specifically the cpu heat sink holder bracket. This is the bracket that the stock Intel heat sink & fan clips into at 4 points. Tried searching archives, and I can't believe I'm the only one that has busted one of these. Damn Intel stock hs&f put so much damn pressure, they usually are the ones that end up breaking (where the little flip-thingy is).
