- Apr 19, 2007
- 2,342
- 265
- 126
I installed the HR-05 on my DS3 with the cushion pad on it (wasn't exactly sure if I needed it or not but the old DS3 sink had one so I placed it on there). Anyway, I apply AS5 after cleaning off the old stuff, and put on the HR-05. I boot into Windows, everything seems fine. I touch the HR-05 and literally feel no heat at all. This worries me that maybe I'm not getting good contact, and guess what? About a minute later the computer reboots and fails to load to Windows. I turn it back on and it just cycles on and off - cold boot issue - at 274 fsb!! I let it sit for like 10 minutes, and turn it back on. It boots into Windows and freezes.
So I take everything out (sigh) again, and remove the cushion pad. Now I'm just running the HR-05 without the cushion pad so I know for sure it is making contact.
My question is though - am I risking shorting anything without the cushion pad on? The heatsink is pretty shaky without and can make contact with the NB PCB where the NB chip is located. However - it cannot make direct contact with the motherboard itself.
So please anyone let me know if I'm running a large risk here by NOT using the cushion pad - thanks.
By the way for anyone wondering - the DS3 does not report NB temps, so I'm going by touch here. The old heatsink would burn my finger after applying pressure on it for 5 seconds. With the HR-05 I feel some heat all over the heatsink but not that much.
