PIII650/100 (not overclocked)
128 MB PC133
Abit BE6-II board with SV BIOS
WD C 153AA-32BAA0 15.3 gig drive
Voodoo3 3000 w/ tv out
SoundBlaster Live! (not working properly, disabled in hardware profile)
Philips CDRW400 USB
WIN98 upgraded from WIN95 w/USB Support
WIN98 Service Pack 1 update
I keep getting Code 11 in the hardware profile for this HPT370 scsi controller(hardware ver. 3)
The device shows no resource conflicts.
I am having the following problems, according to system info.
#1 Plug and Play Software Device Enumerator Code=2 (0x2) Device Failure
#2 PCI Multimedia Audio Device
Code=28 (0x1C) The drivers for this device are not installed correctly. this is the SB Live card, it is currently disabled in hardware profile, i have had problems with the installation of this card on 2 machines. It will always try to install as a SB Live Value, which it isn't.
#3 Highpoint Technologies Inc. HPT370 Ultra DMA100 Controller
This Device Has a Problem: Code=11 (0xB) Device failure:
I have updated the drivers to the latest offered. and I still have problems. The original driver used was the Ultr DMA66 Controller.
I would appreciate any assistance from anyone that really knows what they are doing can offer.
TIA
Cozzmo
128 MB PC133
Philips CDRW400 USB
TIA
Cozzmo
