HPOV NNM and email/ text alerts/ perl help?
Koing
Elite Member <br> Super Moderator<br> Health and F
Hi guys,
Any of you use or develop on HPOV? Anyone used events to generate email/ text message alerts? Just wondering.
Any useful sites? I've taken on this task so any help would be great. I'm currently researching things.
Can anyone help me with some perl? I have found a script off the net but I don't know anything about perl.
Thanks.
Koing
Originally posted by: nweaver
perl is easy, although I have no idea what HPOV is
Okay. The perl part is mostly done now. Didn't have to change hardly anything from the scripts that I managed to find. NOw I'll have to configure it to work with HPOV NNM.
HPOV = HP OpenView
NNM = Network Node Manager
HPOV NNM basically monitors status of network devices and you can do a lot of things with it. I'll need to do a few things.
Koing
Found your thread on Tech-tips. If you want to send alerts as SMS text messages you should look at SNPP services.
I'll get back to you on the email thing...even thought I shouldn't. You should get BMC Impact Manager, the OV integration and Alarmpoint.... 😉
