Originally posted by: Jon855
How many 12grams co2 are there in a nitro 42ci 3000psi tank? And the formula please as I am very curious because I can get around 40 shots off each 12grams co2 with my Phantom Pump.
Originally posted by: PHiuR
if it's a nitro tank...shouldn't it be useing HPA instead of co2?
Indeed but I'm trying to figure how many that of thw 12gram co2 will equal to that Nitro tank. In terms of shot count... I can get around 40 on average per 12gram co2 what can I expect from my 42ci 3000psi n2 tank? Sorry for the confusion.
Why the hell would you use air with a phantom pump?
Co2 compresses into a liquid. Air does not. There is no conversion AFAIK.
I'll take it that you do not play paintball at all, because I can anyways. Anyways sorry about the confusion, I was wondering about the amount of shots that I could be getting from my n2 tank compared to the 40 per 12gram co2.
Originally posted by: Spydermag68
Quick answer ZERO grams of CO2 in a nitrogen tank.
Compressed air used in nitro tank. Vary few places use compressed nitrogen to fill tanks with so they use the closest thing to it and that is the air you breathe.
The best thing to do is to weight your nitro tank empty. Then get it filled and then weight it again.
BTW 1 ounce = 28.34952 grams. On a cold day it takes more CO2 per shot than on a warm day since CO2 is a temperature sensitive gas.
