- Jul 11, 2001
- 41,374
- 10,493
- 136
I had a sense that something was wrong starting a few weeks ago. This printer is little used, I turn it on for a few minutes once or twice a week.
Now, I've had an HP4M printer since 1995 or so, but this HP4M+ I actually found set out on the sidewalk 5 years ago. I loaded it up in the back basket of my bicycle and brought it home. It was dirty, obviously hadn't been used for a while, I cleaned it up and got it working fine.
LED display now is completely blank. A couple of weeks ago the LED display started acting a bit weird. Instead of the usual message when it was ready:
[ 00 READY ]
the LED said:
[ 000READY ]
Otherwise it seemed OK, but as I say, this printer gets little use and probably turned it on only 3-4 times until last week, when I turned it on, it made the usual noises during the self test, and everything looked and sounded as normal except that the LED display was blank. I printed my stuff OK from my PC (i.e. it WAS READY). I did the same today, LED is still blank but it prints without issue.
So, what is likely the problem?
Thanks for help!
PS My old HP4M from 1995 has an issue (I think failing PSU), so I'd like to fix the HP4M Plus if reasonably possible.
[ 00 READY ]
the LED said:
[ 000READY ]
