I recently took a trip to Seattle and brought my PDA with me. On the plane trip there I used my PDA for music, videos, and games.
I didn't use it too much while I was there and on the way back I used it once then tried to use it about an hour later and I couldn't tap on the screen where I wanted to. It seemed like I could only tap in the upper right hand corner of the screen.
So thinking I just needed to align the screen I tried using the buttons to get to the alignment setup. I couldn't withouth tapping the start button so I did a soft reset. That didnt bring up the alignment so I had to do a hard reset. This is when I found out that it wont align. When the screen comes up to tap firmly on the cross hair iIcan tap and the cross hair will move to the next location but it will not align the screen!
Does anyone have any ideas how I can fix this?
My warrenty was up in October of last year. I havent found a scredriver with a small enough head yet to pop the baby open but if I need to I'll see what I can do to get it open. I don't think sending it to be serviced is worth it due to prices but if someone thinks otherwise please let me know!
Thanks!
Thanks!
