HP Quadro 6000 in Custom Build Not Working at All
CalebPetersen
Hi all, I just put together a new computer with components listed below. I'm having trouble with a Quadro 6000 I bought off of eBay. It is apparently getting power as green LEDs near the 6-pin and 8-pin power connectors turn green when the computer is powered on (if either of these is unplugged, by the way, the adjacent LED will turn red). However, it's not recognized at all: if I power up the machine just with the Quadro, I'll never see anything on the monitor, and if I use an older 512MB PCI-express video card and go into BIOS, BIOS doesn't think that anything is plugged into the PCI slot occupied by the Quadro. I believe it's seated properly in the PCI slot, and I've tried both of my PCI-e 3.0 x16 slots. I haven't done any overclocking.
I've tried the card in an old computer (doesn't have UEFI BIOS), booted into WinXP, and it's not recognized at all, not even as an "unknown device". In my current build (and using the old 512MB card for video output) I've also tried changing the Video OpROM from Legacy Only to UEFI Only, but it automatically gets changed back when I restart. Have tried clearing CMOS.
You think this thing was DOA? Is it possible that its previous setup (maybe a workstation in SLI?) left some latent settings that are preventing it from working for me??
Specs:
-Xeon E5-1620 v3
-1x16GB DDR4 at 2133MHz
-NVidia (HP-branded according to seller, although I didn't see any HP logo) Quadro 6000 (not K6000)
-Some old random PCI-express video card
-ASRock X99 Extreme3 motherboard
-500W SP-500 Antec PSU (a bit on the old side and not PCIe 2.0 certified, so have to use molex to 6-pin adapters, which might not be ideal for high performance GPU apps. but I'd think the card would at least get recognized)
-1 SSD
I can boot of a USB stick, so all other components should be fine. Google searches have yielded nothing. I've looked for manuals of any sort for the Quadro 6000, and found only a generic Quadro manual with almost no info about installation, etc..
Thanks,
Caleb
Ketchup
14,559
248
Well, you have plugged it into a slot known to work, as it is powering another card. You are plugging the power connector to the card, and the LED's are acknowledging it.
Unless it just doesn't like your power supply, sounds like you got a bad card.
