HP Printer issue
Dwebtron
61
I'm a college student that has an HP C5180 mainly to print papers. I've extremely rarely used the color ink in the printer. Somehow, the blue ink has run out. Fine, it still let me print in black and white. A little while ago, however, it suddenly won't let me use ANYTHING ON THE PRINTER until I replace the blue ink. What gives?
It literally will not let me scan a document, because I don't have blue ink. I can't print black-and-white, because I don't have blue ink.
I don't want to buy blue ink just to print in black and white. Also, how did the blue ink die when I had never used it?
Lemon law
20,984
My only comment is that you understand nothing about the wondrous rip off of ink jet printers.
What the hell is wrong with you, as you ask what is best for me, when you should be asking what you can do to pad the profits of HP. You were fool enough to buy a HP inkjet,
why should you not have the courage of your brand loyalty conviction's?
To start out with, every time you reboot your computer and inkjet printer, regardless if you subsequently opt to print or not, a small cleaning operation is preformed that runs a small amount of ink of all colors through the print head. That in all likely hood is where your blue ink is going and soon, the same will happen to all your other colors even if you only print in text black.
To some extent you can minimize that every boot ink waste by unplugging your HP inkjet printer from wall power until you need printing, but still, the only good thing that can be said about HP inkjets is they may be marginally smaller rips offs than lexmarks.
I may be somewhat irresponsible in saying the best solution for you is to get a B/W laser printer, but for $50.00 or so such Laser printer would save you a small fortune and you would be well advised to turn your HP printer into a flower pot or just throw it away, But you could be so heartless as to throw that HP working inkjet printer away? Its like your family pet, how could you let it starve to death? You so owe it. This message brought to you by HP. Personally I am racked by guilt as I have let a few inkjet printers die a death of slow tortured starvation, and will certainly burn in hell when I die. Every night, I hear their cries, how could you do this to me? But on the upside, my wallet is far fatter.
But as someone who has a laser and inkjet, it is indeed possible to beat a laser with an inkjet on economy, but one can only do so with some Canon and Epson inkjets, and it gasp takes some knowledge few will bother to learn.
Bottom line, just buy a B/W laser and you will be many dollars ahead at the speed of light.
Pardus
8,197
21
That printer uses 6-separate ink tanks, and it won't print unless are 6 are filled, that's how HP makes there money.
HP could give there printers away and still make money on ink. Canon printers are cheaper to use on ink refills and like Lemon law said, laser is the best way to go.
The only other solution is to re-fill the ink tanks yourself.
Lemon law
20,984
At least ActiveX took the trouble to identify which exact HP inkjet printer it was. While my position was its a HP inkjet printer, its automatically a rip off.
The two minor quibbles I may have with ActiveX in saying, just refill the inkjet instead, lies in two facts. In today's modern world of chipped inkjet printers, refilling your own ink cartridges first involves defeating the chips, no easy task and it takes knowledge. But once one gains the knowledge to defeat the chips, it becomes a quite different degree of difficulty question in the mechanics of refilling. Its dead easy to refill Canon and Epson ink tanks, but its way way way harder to have much success in refilling the printhead on the cartridge designs of HP and Lexmark.
The only non chipped inkjets you can still buy new are made by brother, but they have never been very popular among the heavy ink user photo printing set. As it is, I was lucky enough to buy one of the last non-chipped inkjet Canons ever produced six or better years ago, and it keeps going and going and going on dead cheap refill ink and easily beats my laser on consumable costs.
Anyone who PM's me can learn where I learned about refilling, but unless you can find one of those older still functioning non chipped Canon's, the easy answer is get a laser as the the lazy mans solution to printing economy. About any laser choice will get you to the 1 or 2 cents per page consumable costs arena UNDER ANY USE SCENARIO, and many inkjets come in at 15-30 cents per page at best, BUT ON MOST PARTIAL NORMAL USE SCENARIOS, it ends up being more a dollar a page of output
Dwebtron
61
Lemon, I used to work retail at Staples, and I've seen alot of what you're describing. I know it's a tremendous rip-off, and am happy to hear that I'm not the only one that thinks so.
However, I have yet to find a laser printer that also makes copies and can scan documents...
Lemon law
20,984
Somewhat of a clarification needed, are you talking a B/W laser or a color laser.
If you are talking just a B/W laser, there are a plethora of Brother, HP, and other
makes that will copy, print, scan, have a ADF, and some like my brother 7820N
will fax as well. I saw some black friday links for a brother printer a little better
than my 7820N for like $140.00 shipped.
If you demands color, corkyg has given you a link for one such unit.
Dwebtron
61
Thanks a lot guys! I wonder why the Staples I worked at didn't have any of these...
