HP officejet 4110 system requirement
faye
2,109
Dear All,
want to know what is the minimum system requirement does this all-in-one printer needs.
when i connect it with my usb, it just keeps popup up the "new hardware" found balloon. and it is blocking my desktop process.
The last statement after i install the driver from the cd, it said the hardware wan't installed properly and access denied something like that..
I have a ABit BE6 motherboard, however i will be upgrading very very soon... but i don't know if it is the problem or the printers problem.
so any ideas?
thanks
tenoc
1,270
What OS are you using?
Did you do the installation from the CD before connecting the USB cable?
faye
2,109
WinXP pro
i've tried both ways.
if i disconnect/unplug before i install the cd, during installation, it will ask me to connect the print in order to continue.
Big Lar
6,330
I have the Officejet 7130, and it only likes USB2, does your board support that? If not, that could be the problem.
faye
2,109
people keep telling me if i don't have usb2.0 supported, it could be a problem, and the HP guy said that it couldn't be a problem at all.
but the fact is, my board doesn't support usb2.0( i think),
my board is a Abit Be6(a Pentium 3 board)
so, i don't know if it will support, i already lost the user manual..
and the user manual for officejet 4110 doesn't say system requirement.
Big Lar
6,330
Well, I guess the next step is to DL the latest drivers from HP, and use thier installer, and see if that does it.
Abhi
4,548
I have the same printer...
Used it on a USB 1.1 machine... no problems....
Get the latest installer from HP, run install, and plug it in ONLY when the software asks you to.
There are a lot of known issues and solutions listed on HP's support site...
See if this issue is discussed...
Abhi
4,548
System requirements according to the HP site...
Any Intel Pentium(R) II, Celeron, or compatible processor
64 MB RAM for Windows 98 and Me, 128 MB RAM for Microsoft® Windows 2000 and XP
600 MB free disk space plus an additional 50 MB free disk space for saved images
SVGA Monitor 800 x 600 with 16-bit color
CD-ROM drive
Available USB port**
Internet Explorer 5.0 or higher
Adobe® Acrobat® 4 or higher
Recommended system requirements
o 333 MHz Intel Pentium or higher or equivalent processor
o 128 MB RAM
o Internet access
o Sound card
I am thinking... minimum requirements isnt your problem..
