HP Color LaserJet 4600 network connection died...i think
dalearyous
836
we have an hp color laserjet 4600 network printer and one day it just dropped off the network. i checked the cable and it was fine. however, there is no link light lit up on the network port on the printer. i pulled out the rj-45 connection board and plugged it back in and tried and still no luck. do this things just stop working? should i order new one? i can't think of anything else it could be. i have printed diagnostics and it just states its not connected. the part is a hp jetdirect 615n. anything else i should try before ordering new part?
jlazzaro
1,743
have you connected a laptop to the data jack to ensure the line itself is active? does the card show up in the front lcd configuration as an EIO device? that printer should have 2 other EIO slots on the back, try the jetdirect card in both.
dalearyous
836
at the router side, the jack that the printer is plugged into is lit up. i did connect a laptop to the printer and got nothing whatsoever. i didn't know it had 2 other EIO slots, will try that. thanks
drebo
7,034
Connect the laptop to the wall jack, not the printer.
You could, and possibly do, have a wiring fault between the jack and the switch.
If you do plug the laptop into the printer directly, you'll need to use a crossover cable.
drebo
7,034
dalearyous
836
just as follow through, i tried the printer server in different slot, still no go. i replaced it with one i bought off ebay and it works just fine.
Mar 26, 2008
148
The 615n JetDirects are notorious for crapping out. More often than not when our HPs lose their LAN connection its due to the 615n dying. 620n FTW.
RebateMonger
11,586
I recently spent several hours trying to get a JetDirect card on an HP printer working. The client had always used the printer's LPT port, so the network card had never been tested. I finally gave up and went back to a parallel connection.
