- Dec 30, 1999
- 6,324
- 10
- 81
Will be getting these and I'm about 3000 miles from home so I'd like to set it up quickly and go home.
Originally posted by: spidey07
You'll need help. I don't do servers but I've seen server guys put them in and it's not something you could do safely by yourself.
If you can move it yourself you can easily do it yourself. They weigh a couple hundred pounds
Originally posted by: tomt4535
I think its only 100lbs when its completely stripped, not too bad i guess. Once you get it up on the rails, just gotta push it in
Originally posted by: holden j caufield
haha small world. Guys a few cabinets over all the from halfway across the world got there c7000 in. Stripped it bare and took out the backing and it seems like it's do able by 1 person on the bottom rails. Turns out the cabinets are too tight at the bottom and it won't slide in on the bottom so they had mount it in the middle. Hope it's just their cabinet or their server that was off because that doesn't sound like something I'd like to run into.
BTW if you're ever traveling in ashburn you need to buy cases of beer cause their isn't jack to do in this city.
Thanks, racked it myself. Kind of a pain in the rear but not too bad
