HP 1200 LaserJet printer problem
Nocturnal
Does anyone here work on HP laser jet printers?
My 1200 at home whenever I try to print something the tray lifts as though it is feeding paper and then goes back down and then it starts lifting again as though the paper was not caught.
Is this something that is easily fixed or should I invest in a new printer?
I tried wiping the rollers with isopropyl alcohol and that did nothing really.
I am not familiar with disassemblying printers and fixing them.
If anyone can give me some advice I'd appreciate it.
The 1200 is a great little printer! You can just replace the rollers usually, and they are cheap! Just find a place online that sells them.
