mindless1
- Aug 11, 2001
- 8,359
- 1,555
- 126
mindless1 did not want this discussion to turn into a big debate over passive/active cooling and that's fine. Before everyone runs away from here, could I get some guidance on active cooling:
1. How good is my selection of the Noctua NH-9i + Noctua NF-R8 PWM?
Definitely use the thicker fan on that 'sink if there is room for it, though previously I was not talking about a traditional system build but rather building as if the entire thing was passive, then adding a fan for entire case cooling, just to barely move a little air. I do not own that fan nor whichever motherboard you are going to use so i can't predict how quiet it will be, but it should be reasonably quiet if the motherboard has a fan throttling feature.
2. Would I install the case fan for intake or exhaust? Perhaps I need to run T° tests at load?
I have not kept up on what case you are using which can make a difference.
With a PSU that has a fan forced exhaust, normally the most efficient setup that also blocks noise from escaping is to have a fan under or next to it as an exhaust and block all air intakes besides the one in front of the HDD rack.
If instead it is a passive PSU, do not put an exhaust fan right next to is as this pulls the PSU heat into the case. Instead you'd want an intake fan on the opposite corner of the case or for lack of options if the PSU is on the bottom of the case and drive rack up top, then the fan on the bottom front.
3. Do I need to add any special air filter (the case has none)?
Need, no, but it sure is nice to cut down on dust, to open a 2+ year old system and see it shiny like new instead of dusty.
With exhaust fans and modern cases with holes everywhere you should seal up all holes and gaps except on whichever area you deem large enough to place a filter panel on.
It need not be one of those little fan sized screw-on types, in fact I don't recommend those at all in favor of a much larger filter area medium placed between the case front bezel and case wall if there is no other way to accommodate it. Other areas can be blocked with common packing foam to create a channel so practically all intake air goes through the filter, though even if there are a few small leaks, that's a lot better than nothing.
Popular filter mediums include trim to fit panels made for wall A/C units or slide in pleated filters made for central furnace stacks... better filtration than the former but significantly thicker so it will not fit in as many places. Either can be found at larger hardware stores.
I want to emphasize again that I have been referring to extremely low fan RPM, just enough to get the fan to reliably spin up at power on, with that specific fan RPM depending on the fan model and method used to control RPM. For example the same fan controlled by PWM vs resistive or transistor biased throttling, could potentially result in a different minimum RPM setting needed to spin it up.
Fortunately motherboards that adjust fan RPM based on temperature can compensate in that if the fan failing to spin up causes temperature to rise then the fan gets more juice to spin up which can be reduced later once the temperature drops.
