Decent but could do better. Tuck the cables through the holes, seems a little bit loose. Hide more lengths of the cable behind. Remove the upper drive cage and use the bottom half, less airflow restriction from the fan blowing at the front. Not liking the SATA port placement, looks like you're weaving the cables for some reason. Would've looked a lot neater if the SATA ports were angled on the edge of the motherboard.
