How's my system
luminantlapis
25
Not for playing games
CPU: Celeron4 2.4G
MB: Abit IS-10(865GE)
Monitor: Sharp LL-T15A3HB
Optical Drive: Pineer DVD-121A
Memory: Kingston DDR400 256MB
Harddisc: WD WD2500JD
Power Supply : antec 350W
Case: Cooler master---Wave Master(TAC-T01-E1C)
Keyboard: Microsoft Internet Keyboard
Mouse: Microsoft IntelliMouse Explorer 3.0
JammingJay
1,547
Agreed - stepping up to 512mb memory (especially if running XP) would probably be very beneficial to you. Dual channel isn't crucial, for you're running a Celeron AND it honestly isn't that much faster.
Lonyo
21,938
Don't get a cheaper case, but get a Barton 2500+ (shouldn't be too much difference in price).
Regs
16,665
21
Agreed..
Oh god no, not a celeron. If you wanted a cheap CPU then you should look at the AMD's. 90 dollars for a 2500 barton will be at least twice as fast than that over priced celeron.
chocoruacal
1,197
Since you asked...I think your system is a waste of money. I think you are the perfect candidate for a Dell. You spend $150 on a case, then another ~$40 for a power supply.............and then you buy a Celeron. LMAO...that makes no sense, regardless of what you plan on using it for. And its not that the Celeron is particularly slow, its just that its a poor investment when you think about how the Barton will destroy it.
Barton + nForce2 + 512MB pc3200 + Antec 3700.
BurnItDwn
26,330
1,841
thats fine for not playing games, however its going to perform on par with CPUs that are rated at lowwer MHZ speeds.
ie, an athlon xp 1700 or a p4 1.8 would rip that celeron a new one.
Also, 256mb of ram is ok for most things, but if you expect heavy usage, and want it to last a long time, I'd strongly advise to get 512MB of ram or more.
ZL1
5,383
I'll second the 512MB tip and the Barton over Cel tip too
D
P.S. whered u get a sharp monitor ? havent seen those in a while
Johnbear007
4,570
The celeron is a total waste of money, as well as the case + power supply. I fyou want a a high end case and psu get an ANTEC 1080 AMG it is more than sufficient.
I second the notion that you should just get a dell.
