Hows my rig for its first oc?
LearnedPadawan
10
My specs are A64 3400, X800 Pro, K8V SE Deluxe, 1GB Corsair XMS memory and two barracudas (160 GB each) in a Raid 0. I'm going to start with ocing my cpu.
Apr 17, 2003
37,622
nice, the board doesnt have AGP/PCI lock so i think you are good to up near 220-225 FSB. wouldnt push it more than that
BW86
13,114
30
oooh i wouldnt oc that high without a pci/agp lock, especially with 2 sata drives in raid
Lithan
2,919
Some/most/all k8v se deluxes have a 1/7 pci divider. If you have a spare hard drive, set it up and drop your multiplier, then play around at 233, see if it's stable... then try 232, see if it isn't stable. This has a good chance of telling you whether of not your divider is kicking in. Don't use clockgen, you have to do it from Bios. Also be sure your ram is fine at whatever speed it will wind up at.
