How's ford 6cylinder 4.0l engine?
jsbush
3,871
How were the 6cylinder 4.0L engines which were found in the Ford Explorer in 96-97? Are they reliable, and can handel a lot of mileage? How are they on gas?
Thanks
CraigRT
31,440
Isn't that a Mazda motor? Not sure on that.
my cousin had one in his Explorer.. it wasn't bad by any means..
upsciLLion
5,947
I'm not sure about the later models, but the 4.0L V6 in my '92 Ranger is rock solid. I has about 135k miles on it, and runs clean and very reliably. It's not terribly powerful, but the less strain on an engine the better it is for it (or so I've been told).
Heisenberg
10,621
:confused:
..the less strain on an engine the better it is for it... huh?
thomsbrain
18,148
135K doesn't count as "rock solid." oh wait, we're talking about american cars. yeah, that's rock solid. ;)
upsciLLion
5,947
:confused:
People keep talking about how Neon SRT-4s hopped up with tons of mods are ticking time bombs because of the extra stress put on the engine. If you don't do that, then it's easier on the engine.
Does that make sense?
Heisenberg
10,621
:confused:
I see what you're saying now. I agree about the less strain the better in principle, but it is possible to build powerful motors that are rock-solid. The problems usually start when you modify the engine beyond what it was built to do.
slag
10,473
Well, that depends.
There were 2 4.0 liter engines in that year Explorer.
There is the 205ish hp 4.0 liter SOHC which was notorious for having timing chain problems. (required pulling the engine due to 2 chains, one on the front, one on the rear of the engine. Most of these were fixed under warranty, but for those out of the warranty period, you are SOL.
Then theres the venerable 4.0 ohv engine, makes much less hp, but is very very reliable and you can easily see 200k miles on these engines and they keep running. Idle generally isn't that great, but the engines themselves run very well.
upsciLLion
5,947
Gasoline is a little harder on engines than rice is.
DanTMWTMP
15,908
19
i have a '97 explorer. The mileage sucks. Power is a bit lacking.
overall, it's a great vehicle. It has about 140k miles on it, and it still runs smoothly. Well, the spark plugs, filters and such has been replaced, but overall, there's nothing wrong with the engine so far. Just make sure to do regular oil changes and stuff i guess...
I get approx 16-18 city and 19-21 highway, if lucky.
The mileage is the only complaint I have on this car. I guess that's expected from a 4L V6 SUV that outputs around 150ish hp (someone look this up for me, i donno how much hp this sucker has hehe).
OrganizedChaos
4,524
as stated the SOHC engines can be a little flakey. the OHV engines are industructable with regular maintence and if you don't abuse it ( known for cracking a head if overheated)
arcenite
10,660
7
:confused:
I was told the SRT-4's stock block was built to handle an upwards of 650horses... If that's the case, there should be no problems below that, right?
edfcmc
531
it appears there might be other issues one should consider in addition to the engine. According to this attorney, explorers are notorious for rollovers. (Yeah I know....this guy could be considered an ambulance chaser)
Link about rollovers
SuperTool
14,000
:confused:
Handle and handle reliably are two different things. I would like to know what mean time to failure of 650hp SRT-4 engine vs the stock engine is.
bernse
3,229
It's decent enough, but it anin't any Jeep 4.0L straight 6. *THAT* was an engine.
Zenmervolt
Elite member
Oct 22, 2000
24,514
43
Originally posted by: slag
Well, that depends.
We had an Explorer with that SOHC 6. Towed boats with it, ran it around for over 150,000 miles before it died when a motorhome couldn't be bothered to stop and ran right through the back of it.
Never had a lick of trouble with it and we never got any warranty notifications on the truck.
Was a great engine for us.
ZV
NetWareHead
THAT guy
Aug 10, 2002
5,847
154
That happened to me. 2 blown head gaskets led to a slow anti-freeze leak till one day it overheated. When I got the head gaskets fixed, the mechanic pulled the heads and found both were cracked. The bill came out to be $1700.
jsbush
3,871
Hmm.. Scary stuff.
Any recomendations for an SUV in the same price range and class as the explorer?
johnjbruin
4,401
We have a 98 - it has the 4.0L V6 that produces 160 hp. Never had any problems with the engine.
OrganizedChaos
4,524
Hmm.. Scary stuff.
its been proven many times that the drivers have to over compensate several times in quick succesion to happen. people here a blowout and jerk the wheel then go off the road, jerk the wheel again to get back on the road and end up sideways and then roll. if a tire blows on an explorer it barely changes direction. however if you slam on the brakes it will pull to one side because only 3 wheels have traction. the problem isn't a high CoG its that people can't drive.
