you could add a molex connector to it
you could also add it to a rheostat(variable resistors) and adjust the speeds as needed
or you could just cut a wire real quick, strip them with your teath, then tie them together real quick with yur fingers
but i don't recommend the last option
i modded a case i built to have 13 adjustable speed fans mounted in the case, above, below you name it
