- Nov 19, 2007
- 2,793
- 2
- 0
Originally posted by: BlueAcolyte
Title says it all. I wondered why it wasn't spinning...
Ah I see. Is it possible to use hot glue to hold the wire? I don't have access to a soldering iron.
The glue wouldn't be electrically conductive, because it's wax.
it should have 3 places for leads.
Red, Black and Yellow.
Red and Black is reversable. Meaning if you plug the red with black instead of red with red, the fan will spin backwards!
If you connect a red with yellow the fan wont turn on.
Red and black = +/- Yellow = RPM Sensor.
The hard part is the cynoacrylic, im assuming crazy glue, will also insulate the connection.
If you really dont want to fiddle with it, then just use industrial tape, or something that wont fall off or rip off when you attach the leds.
But i do recomend a solder. The top should only be if you really dont want to do it, and you really dont care.
20 dollar solder to fix a 5 dollar fan is rediculous.
