Yeah, I remember having a hard time figuring it out at first, but it really is simple *once you get it*
I'm at work now, so no opportunity to check it. I'll give it a try at home if hte thread is still active. Or just poke around a bit more, I have not used it for at least 10 months - it always takes a bit to figure it out again.
I use efax, but really just their free service to receive faxes over the internet. I know they let you send them too, but it might cost ya. (Sends it all over the internet though, through email, and can come out on a fax machine at some other phone number that you give them)
