NetWareHead
THAT guy
- Aug 10, 2002
- 5,847
- 154
- 106
pressure
Shhh I want to see pics of a collapsed roof and a future thread "My landlord evicted me and suing me for a new roof; what do I do??!!?" thread. Go on op and ignore my earlier advice
pressure
Why don't you just ask one of your neighbors on the fourth floor to help you out? Run a hose from one of their sinks up the steps to the roof. Should fill up pretty fast.
I think you should double up and get two pools up there.
"hay neighbor, I want to put this 200 gallon pool which will be heavy as shit on the roof right above your apartment. I was wondering if I could use your sink to run a hose to fill it up?"
what could possibly go wrong there?
Is there enough room for bean bag game and maybe a cookout up there? Might I recommend hauling a turkey fryer up to your roof?
Excellent! A fryer fire will get the party foamed and the fire department will fill the pool at the same time! The op will be an instant media hit and the party will become legendary.
A disco ball will reflect the fire engine's spotlight beautifully if you do this at night. It could be a foam party with laser light show!
I wouldn't worry about the weight. Buildings with flat roofs and tenant access are typically well built. We are talking steel I-beams.
Talking about about this with some friends and one mentioned that you might, might just have to ask your landlord and the city.
The beams will be fine as long as he doesn't cut them with thermite first.YMMV.
But I-beams a good thing, even planes ramming into em can cause problems though.
:thumbsup:
You could put a net up between them and play water volleyball.
