Only 200 gallons? Is it 3.8 gallons/liter? A kilogram per liter? Can't go wrong with a 760 kilogram load.
watch it crash through the roof.
Yes, I specifically opted for the smallest pool they had. The water itself couldn't weigh more than the people, furniture, and other crap that's up there.
Some don't allow waterbeds, some do. The pool is smaller than a twin bed.
I can assure you, you are very wrong. That water weights a lot more than the furniture and people. Especially in terms of pounds per square inch of weight.
This seems like something you should have though of before buying a pool.
...The building is four stories and I live on the bottom floor, so a water hose from the kitchen won't work.
/thread
Still less than a waterbed. 1600 lbs for 200 gallons. OP will be fine.
So on impulse, I bought an inflatable kiddie pool. 5 feet wide. I got the idea that I could put it on the roof to have a hot, hot bikini pool party, but how would I fill it?
My first thought was to carry the water up in buckets, but it would be about half a ton of water to carry up five flights of stairs. That's like helping a friend move. And having to to do it several days in a row as the water gets dirty is a no go.
Also it rained yesterday, so that's a good start. :thumbsup:
Is there some kind of fancy water pump that will shoot 50 feet into the air with no issues?
Can I connect it to a fire hydrant? Are there dozens of laws against that? Is it remotely safe?
A faucet doesn't have enough pressure to push that much water straight up.
If there is anything on this earth that the OP doesn't need, that one thing would be retardant.
What, is the OP hiring Echo Valley or something?That's nothing compared to the entertainment he's hiring.
Because it's coming from a big pipe which connects to a small pipe, which kills the water pressure. I can cut off the water flow by covering the faucet with my finger.
Is this a multilevel apartment? You should put the pool at the end of the roof, with a slip n' slide leading to a ramp into the pool. Then watch hilarity ensue.
However, you are doing it wrong. You need to fill it with liquor.
I think you mean cubic inch. And to be honest, it's not a lot more.I can assure you, you are very wrong. That water weights a lot more than the furniture and people. Especially in terms of pounds per square inch of weight.
