Scarpozzi
- Jun 13, 2000
- 26,389
- 1,778
- 126
I suggest burning $18 or so on a 12v battery operated bilge pump at Walmart (in the boat section). Then get as many feet as you need of 1/2" clear flexible vinyl hose. It usually goes for like $.33/foot or something.
http://www.walmart.com/ip/Shoreline-Bilge-Pump/16609598
http://www.lowes.com/ProductDisplay...gId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
You will need some pvc or brass fittings because that bilge has 3/4" output, I think...but those shouldn't be a few more bucks. You then just need a 12v dc power source. If you know someone with a trickle charger that'll do 2amps, you can set that up next to a bathtub and let the pump run from there.
