How wide are these tires?
I'd say 285 is a good bet. As far as they stick out from the wheel well, they should be 315, but the wheels have a bad offset for the car, and push the tire out further than it should be.
275-285, but I challenge anyone to be able to differentiate 10 mm from a picture like that.
My roommate has 315's on his Corvette, they're biiiiig. Much bigger than the tires in this picture.
I was thinking 245 maybe 255, but 95SS is right, the offset on those wheels is terrible.
On my 95SS, I had forgeline 11" wheels and 315's on the rear and from the side, you couldn't tell. It was a sweet setup and looked very nice.
Those can't be 285. The inner rim is only a few inches from the outside panel. Tricky mod to make the rubber look fat.
