- Sep 19, 2004
- 1,563
- 0
- 76
My case came with three probes for the front LCD display. They are a long black wire with a metal tip that measures temperature.
cpu
I'm using a thermaltake big typhoon and I have no idea where I could measure the temperature. Maybe like this (Clamp, Probe, Copper, Chip)?
hdd
This must be the easiest of the bunch... where exactly should I stick this on the HDD? Top, bottom side, anywhere?
sys
I'm assuming by sys they mean the chipset, but I have a dfi mobo with that big circular fan so I don't know where I would put this. I could use it to measure ambient case temps, then again I wouldn't know where to mount it.
mounting
The manual doesnt mention what I should use to mount these probes...
cpu
hdd
sys
mounting
