how well will Skyrim run...
AdamantC
478
Quite well as others have pointed out. I ran it fairly well at mid to high on a S939 Opteron 175 @2.53 and a GTS450 @1280x960.
Bateluer
27,730
8
Skyrim can run on an Intel HD4000 alright with some tuning. Targeting the ancient X360/PS3 hardware means its PC requirements are fairly low.
alangrift
434
The game should run well enough, but I recommend you get a graphics card or you might have some problems.
Aug 11, 2008
10,451
642
I think you should be able to run medium settings. What resolution are you planning to use? I just noticed that the 7750 you have is DDR3, so that will probably be the bottleneck, but it should be still playable.
Zeze
11,395
1,188
Extremely well.
When Skyrim first came out, I was extremely excited yet worried because of my old rig was pretty outdated- Phenom II & HD4850.
With AA & Vsync turned off, it ran well absolutely beautifully- 50 fps on 1920 x 1080 with HIGH details.
The game looked beautiful on that aging old rig.
So Phenom was like what, 2-3 generations behind i3? And HD4850 was a joke.
futurefields
6,470
32
maybe at the absolutely lowest settings. personally I would rather hook up to a 720p TV and run at medium/high settings.
poohbear
2,284
Vanilla skyrim will run perfectly fine on that system. Skyrim with graphics mods is a different story entirely....but stick with vanilla & u'll be fine.:)
Bateluer
27,730
8
A 7750 will easily handle Skyrim at much higher resolutions than 720p. With an HD4000 IGP, he'd be looking at 720p. With a 7750, 1080p with lower AA/AF will be well above 30fps as its 31fps with 4x MSAA/16xAF.
From AT Bench: http://www.anandtech.com/bench/product/535
The Elder Scrolls V: Skyrim - 1920x1200 - Very High Quality + 4xMSAA/16xAF
Frames Per Second - Higher is Better31.6
The Elder Scrolls V: Skyrim - 1680x1050 - High Quality + 4xMSAA/16xAF
Frames per Second - Higher is Better58.8
Frames per Second - Higher is Better73.8
DigDog
14,449
2,874
compared to Oblivion, the only thing Skyrim did really well is optimization - it runs really good even on average hardware from 2 years ago.
(i didnt like skyrim; but you know about that already)
http://forums.anandtech.com/showpost.php?p=35888762&postcount=4
Morrowind is my favorite Elders Scrolls game. There are some great mods that really improve the graphics. Of course, the graphics won't be as good as Skyrim, but they are good for a game released in 2002. See here and here for examples.
That said, don't go into Morrowind expecting it to be be like Skyrim. Morrowind -> Oblivion -> Skyrim was a trend of 'streamlining' and 'accessibility changes'. As such, Morrowind is the most deep but also the most complex and hard to get into.
First of all, damage is based on stats and dice rolls. When you swing your weapon at an enemy, it calculates whether or not you hit that enemy based on your character's skill in your particular weapon. This is one of the most jarring things to get used to coming from Oblivion's and Skyrim's combat system. Numbers mean a lot more in Morrowind.
Secondly, the world isn't all scaled to your level. This is true for both mobs and loot. This means that you can easily go into a dungeon only to get mauled to death because it is filled with vampire lords and you are a level 1 newbie. But is ALSO means that you have a real reason to explore caves, dungeons, and ruins because there may be some great loot inside rather than just a rusty iron dagger. It also allows the dungeons to be specifically crafted in such a way to hide treasure in little nooks and crannies, so the incentive for exploration is much greater.
Thirdly, the the armor and weapon system is more complex. Rather than juts one big suit of armor like in Skyrim, you have individual pieces. In Morrowind you have your helmet, left pauldron, right pauldron, cuirass, left glove, right glove, gauntlets, and boots. On top of this you can wear a robe, underneath you can wear clothes (shirt, pants, shoes). Morrowind has more weapon types as well, including differentation in long blade and short blade, spears, and crossbows.
Lastly, the quest system in more involved. You keep your quest info is a journal, and there is no automatic marker or trail telling you where to go. You have to actually listen to what people tell you and follow their in-game directions. There is also no fast travel, although you can pay for similar services in town to catch a ride or teleport to another town. There is a ton of additional dialogue since the game isn't voice acted, even with random NPCs. You can kill any NPC, but if you kill one important to the main quest it will give you a warning.
So overall I'd say it is a great game but it is a bit different than the sequels. Go in with an open mind and hopefully you will enjoy it. You question makes me want to reinstall the game....
Red Hawk
3,266
169
Not only that, but the game just looks better than Oblivion, both as a result of more advanced rendering techniques and a more distinct art style.
I'm not sure why you quoted that post in a thread that's not about how good Skyrim is, other than to toot your horn yet again about how much you dislike it. But as long as you're at it, I'll say that complexity =/= depth. The only thing that really sounds appealing from that post is the more varied weapon types. Enemy scaling is actually something I'd say Skyrim did better than Oblivion, it was more refined so you wouldn't get random bandits and stuff at crazy levels and carrying overpowered items.
futurefields
6,470
32
are they testing the GDDR5 version? Because OP has the 7750 DDR3 which wont perform as well especially at higher resolutions.
blastingcap
6,654
DigDog
14,449
2,874
everything that you said, but opposite.
i guess old school RPG players like it my way, but its ok if you like games to hold your hand.
