How well does usb to ps/2 kybd+mouse adapters work?
JEDI
29,391
2,738
all of my keyboard and mice have ps/2 connections.
new mobo i want to buy for i7:
http://www.microcenter.com/single_product_results.phtml?product_id=0371775
that's the only mobo in stock at microcenter that will give me $50 discount w/i7.
it does not have any ps/2 ports.
How well do usb to ps/2 adapters work ($9)?
http://www.microcenter.com/single_product_results.phtml?product_id=0230515
http://www.microcenter.com/single_product_results.phtml?product_id=0303624
or just buy new usb kybd and mouse?
ViRGE
Elite Member, Moderator Emeritus
167
Frankly I'd just get a new keyboard and mouse (PS/2 is only getting deader), but if you'd like to keep what you have then adapters work fine.
MonkeyK
1,396
8
The adapters work great. But newer mouses tend to be better than older ones.
If you have a nice keyboard, I can see wanting to stick with it.
DaveSimmons
40,730
670
I use them with my gaming PC and music jukebox because my old KVM switch is ps/2 not USB. They mostly work fine, the issues I've had are:
- Once in a while the KVM or USB adapter gets confused and repeatssssssssss a character until I hid backpsace or something else to stop it. This only happens once every few days.
- Some bootable CD software like old versions of Acronis True Image rescue disk might not see the keyboard or mouse. Newer software and the BIOS on my new socket 1155 motherboards are fine with it.
mfenn
22,400
www.mfenn.com
You lose NKRO by going through a PS/2 to USB interface, so unless you have a very nice PS/2 keyboard with mechanical keyswitches, you might as well just replace it with a new USB board IMHO.
JEDI
29,391
2,738
whats nkro?
bononos
3,924
184
n-key rollover, the number of keys a keyboard can take in before it stops registering. Important for gamers eg. you might want the caps/shift/ctrl/wasd keys to be able to work together even if most/all of them are pressed down. The ps/2 interface has the advantage of being better at nkro.
mfenn
22,400
www.mfenn.com
:thumbsup: NKRO is one of those things that your either really need or could care less about depending on your usage model. For me at least, the 5 or whatever simultaneous keypresses that you can do with USB is sufficient.
