How To Wire a Rosewill Case
While assembling my wife's new computer I misplaced the wireing diagrams (if any) that came with the Rosewill TU 155 case. I have most wires figured out but there is one from the front of the case at about the position of the power switch that doesn't seem to match any sockets on my Shuttle AN 35N ultra. It has two large male pins that are in a nearly clear white plastic connector with a clip on one side. The wires are not twisted like most and are medium blue and white. Has anyone built one of these? Let me know what its for and where it goes. Thanks!!
do the connectors look like the ones you connect from your power supply to the motherboard?
have you tried turning on the computer? if this is indeed the power switch lead then hitting the power switch on your Rosewill won't do a thing
ive never heard of a power switch lead being that huge, however....
The connector is nothing like the power connector to the mb. It is about the size of the 4 pin aux power connector except it has only 2 pins and they are male and bare not recessed inside the connector. I haven't turned it on because I don't want to set off any problems. The connector looks like this: ][= , and the pins are about 1/2 " long and 1/4 " apart. The clip is close to the pins; a bit shorter and wider (>1/4 ")
they sound really big...bigger than anything i've ever seen coming from a case
in my case, blue and white cables represented the lights on the front panel (i have 4 blue LED lights...no function, just cosmetic). do you by chance have a temperature monitor or any sort of special function on the case?
in terms of what u NEED to connect to your mobo from the case, there really is only the power switch, reset button, and HDD indicator.
I don't think this cheap case has any special lights. I don't even find the connectors for the hard drive led or the doze mode led. I have the speaker, power-on and reset connectors and some for front panel audio and video. Dont have a clue about the mystery connector.
bump. I'm hoping someone sees this that knows Rosewills. I emailed them and got no reply. Any suggestions of a different forum to post this would also be appreciated.
This is my final post. I found an adapter that turned the mystery connector ino a standard molex power plug. So all that worry was solved in the spare parts that came with the case. Thanks anyway.
