How to Use Finder for File Searches - Help!
dmw16
I'm not sure if it's just me, but I suck at using finder. I typically use quicksilver for finding applications and such, but in I'm in a situation where I need to find a bunch of files.
For some reason when I imported my iTunes library from my old computer it duplicated pretty much every song and created a copy ending in " 1.mp3". In windows finding all of the files at once would be a trivial task as would deleting them.
However I can't figure out how to make finder find them all so I can delete them enmass. Any help?
Thanks,
Doug
Thanks,
Doug
You mean a Spotlight search for "1.mp3" does not work?
MotionMan
I was using whichever search is in the top right of the finder windows. It's actually amazing to think that I've been using a mac for years now and still some basic stuff eludes me.
I found them all using quotes, the *1.mp3 search didn't work tho.
That is Spotlight. It says Spotlight when you click on it. 😵
Did you try it without the *?
MotionMan
