Well since everybody and thier monkey has thier AIM name posted in thier sig, or in posts I decided this just might be useful around here.
not exactly a FuseTalk enhancement, but if you want to do AIM links in posts or in your sig, use the following URLs, it redirects to aim: links, which are not supported in FuseTalk (yet) you will need to replace the end of each URL with the appropriate screen name or chat room.
If you want to have a link to send you an IM:
[ L = IM Train ] http://www.racemonster.com/goim.asp?screenname=ypsineil[ / L ]
(without the spaces)
or for a link to add a name to a buddylist:
http://www.racemonster.com/addbuddy.asp?screenname=ypsineil
or to link to a chat room:
http://www.racemonster.com/gochat.asp?roomname=TeamAnandTech
These will work if you have AIM 2.0 or higher running, i have it in my sig and it seems to work fine for me. They are simple 3 line ASP scripts, which should run pretty fast, but if you are on a slow comp or slow connection, it may take a second for the AIM window to come up.
