how to ungrease a doorhinge without removing the door?
CPA
30,322
4
For doors that close on their own.
Pull hinge pin.
Lay on hard, flat surface.
Give it a smack with a hammer.
The slight bend will cause pressure in the hinge keeping the door from closing on it's own.
For heavy doors, you may have to do more than one pin.
hmmm, I may try this. What happens though if you can get the pin back in the hinge? I'd have to buy a new pin and be right back where I was at.
dank69
36,045
30,333
The WD-40 will not work. In fact, WD-40 is what I use to lubricate my door hinges.
Back to the original problem - using a couple of twist ties to create friction between the pin and the hinge worked pretty well for me.
Do you have to lubricate your hinges again after time?
natto fire
7,117
10
Yeah, WD-40 is not a true lubricant so much as a penetrant and water displacer, but it does contain lots of petroleum ingredients which act as lubricants.
So even if OP sprays WD-40 to displace the moisture in the cooking oil, which is very minute, especially if it is a non-hydrogenated oil, then he is still stuck with residual lubricating petrochemicals from the WD-40.
If the only variable was time, then he would be better off letting the cooking oil crud up, over "treating" the cooking oil with WD-40 and allowing that to crud up...
wabbitslayer
533
after considering all of the methods and alternatives suggested here, it would probably just be simpler to get a replacement wife.
slag
10,473
If you cook a few pancakes on the hinge, they will absorb the cooking spray right up.
alkemyst
83,769
19
To clean out the hinges you will need to be careful of the door finish as well as what the hinges may drip on. Some 'handyman' went through a friend's house and apparently graphite was used in the hinges at some point. The clear spray he used worked, but it dripped leaving dark black marks in her carpet in several rooms.
dank69
36,045
30,333
That's why I was asking him. WD40 may "lubricate" for awhile but it will wear off. Better to use lithium grease.
notposting
3,489
30
Guys, some roof shingles blew off. I threw some buttered French toast I had on my plate up there, but they keep slipping down. Should I go back with some maple syrup to help them stick better?
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Noob! Everyone knows you use Graham crackers and marshmallows.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Bah. The crackers get soggy. Instead, get some of those premade pie crusts. Unroll them and stick them in place on a sunny day. After they dry up, they'll probably survive through anything less than a hurricane.
Get with the times! Use pop tarts, they're already the right shape and they're insulated.
RelaxTheMind
2,245
have a tube of marine grease that i bought about a decade ago. been using it for hinges both indoor/outdoor, computer chairs, fishing reels...etc and only 1/4 of it is gone.
best $8 i ever spent.
alkemyst
83,769
19
That is some strong smelling stuff usually and with door hinges in a home, good luck if your clothes took that stuff.
