What is the easiest (read cheap, but still safe) way to undervolt both case fans and cpu fans (all 80mm). I know I can get a Zalman fanmate for the cpu fan, but is there an equivalent alternative.
And for the case fans (2) should I just tap into the 5v lead and ground from one of the 4 wire connectors from the PS...is there any danger to this, and can I do both on the same connector (or would 2 fans present more of a load, and thus they would not really be running at 5v each?)
Any help you can give me would be appreicated
