how to tweak NIC settings...?
TJN23
quick question...
i heard setting a NIC to "promiscuous mode" can be bad, allowing all frames that would normally get dropped to be accepted by your NIC, which can also pose a security risk...
is there a way to set your NIC to this mode, or do any other kind of configuration to your NIC, such as set it to 100Mbps (instead of autosensing 10/100Mbps)?
Thanks,
Tim
What specific NIC and workstation OS?
As an example, in Win2K:
My NetWork Connection
Local Areas Connection
Properties
Configure (for the NIC)
Advanced
Options there will vary from NIC to NIC.
