How to troubleshoot if my DVD-RW drive is working or not.
Shargrath
162
Hello,
I think my DVD-RW drive might be broken. The drive has no issues reading discs, but whenever I try to burn anything, it tells me that it failed to burn. I tried several kinds of media (brands) from several different packages, and it is not working on any of them. If it wasn't reading discs, I'd have thrown it out and replaced it by now, but it's only giving issues burning. I tried multiple programs to burn as well so I don't think it's a software issue.
Device manager doesn't show any errors or issues with the drive.
Any way to make sure it's something wrong with the drive?
I am running Windows 7 pro.
Thank You.
UsandThem
16,068
7,383
It sounds like you have done all the reasonable troubleshooting steps (outside of trying it in a different PC). You can try burning a disc at a low speed to see if it makes any difference.
But since DVD burners are so inexpensive, it might just be worth buying one and calling it a day.
Shargrath
162
Im just concerned it winds up being some soft of software/windows driver issue and a new DVD-RW drive would do the same, so I want to rule that out...
UsandThem
16,068
7,383
Then just try burning an audio disc from with Windows Media Player. If it still has errors, just buy a new drive (or continue troubleshooting if you like).
How old is this burner? If it's older than say 5 years, just save the time and buy a new one for under $20. They eventually wear out.
Billb2
3,035
70
86
Clean the laser lens with a rubbing alcohol and a q-tip.
Reactions: VirtualLarry
Iron Woode
31,295
12,817
could try flashing to a newer firmware.
still, I'd just replace it.
Oyeve
22,066
883
$20 bucks for new. Better than the $600 I paid in 2002. For 2x burning. Good times.
