How to trick mining rx 570 dvi into freesync?
eurgbp
27
bought a rx 570 with only one port - dvi
how to trick it to freesync then?
monitor is freesync ok
Krteq
1,005
713
You won't be able to do that. FreeSync require DisplayPort or HDMI.
Krteq
1,005
713
Well, to be more precise, you need DisplayPort because FreeSync is basically an AMDs implementation of VESA DisplayPort Adaptive-Sync.
In case of FreeSync over HDMI, it's AMDs implementation of VESA HDMI VRR draft specs. Now HDMI VRR specification has been implemented in HDMI 2.1 standard.
So, physical connection is irrelevant because DVI doesn't supports required protocols. Adapter won't help
eurgbp
27
so if card rx 570 has hdmi port then freesync is ok?
or it must be a hdmi 2.1 and not hdmi 1.4?
