How to tell (visually) between Geforce2 GTS and Pro?
Liquidity
I have an engineering sample ELSA GLADIAC Geforce2 64mb, either GTS or Pro. Is there a way to tell by looking at it (or any other way) which it is? I'm just curious.
If you are using the latest drivers and coolbits, if the memory reported is running at 400MHz, then it is a Pro. If it is runing at 333MHz, it is a GTS.
check the ram, if they are 5ns , you have a pro version, anyhigher you have a normal version.
steve
