How to tell true processor speed?
GizmoFreak
How can I tell what speed my processor natively runs at?
I inherited a computer, which I think may have been tweaked with. It seems to run fine at both 600 mhz (100mhz bus) and 800 mhz (133mhz bus). But I can't tell which is the true speed.
This is a Pentium III chip.
Is there any way to find this out?
I have a Pentium 3 800EB which has the 133mhz front side bus and a 800mhz clock.....if it says the EB maybe it is the 800mhz clock it is native at.
Any way I can find out which one my chip is?
Will it say on the chip? I'd prefer not to have to take the heat sink off.
Is it a Dell or Gateway or something? I think most of those companies put labels on the back with a number where you can look up the exact system configuration on their web sites.
What OS?
XP will tel you..
I had a 2.4b@3ghz and it would show under My Computer - Intel P4 2.4ghz
P4 @ 3ghz
Or something to that effect
WCPUID or Cpu-Z may do the trick.
Originally posted by: bjc112
What OS?
XP will tel you..
P4 @ 3ghz
Not always... my friend's Dell Notebook with an 866 Mhz P3 says "866 Mhz Pentium compatible" or somethin like that... says nothing about the actual model.
CPU-Z should be able to tell you the model/id/stepping info, which you could hammer into Google to find the specs. Like mentioned, "E" = bonus cache, "B" = 133FSB. You either have a 600E or an 800EB.
- M4H
