How to tell difference X2 4400+ 110w vs 89w?
vvume
11
I just discovered that there are two variations of the X2 4400+ - a 110w part and a newer 89w part. How can I tell the difference using Cpu-Z or using some other software means on an existing installation?
vvume
11
I took a look at that link before I posted this question. The problem is that both Open PIB part numbers are the same: ADA4400CDBOX - there doesn't seem to be any other information that can distinguish the cpus. The only difference is in the OPN (Tray) - I don't know what this means - where the 110w model is ADA4400DAA6CD and the 89w model is ADV4400DAA6CD. I bought the Process-In-Box (PIB) in mid-Jan'06 through Dell.
stevty2889
7,036
8
They both have the same box code, and both have the E6 stepping, so basicly I don't think there is any way for you to tell the differance.
KBTuning
357
what temp do they run.... im guessing thats the only way to tell unless someone finds out the Steppings of the new 89w chips...
vvume
11
I overclocked it right from start: 2200MHz -> 2651MHz. Under overclock conditions it hovers around 34 idle and 42C Full load. I use a venus 12 cooler and run the variable speed fan at around 3500rpm which is closer to the lower end of its speed. Should this mean that it is a 89w part?
formulav8
7,004
522
Are the 89w chips a new strand of silicon or something that just been released?
Jason
HO
216
ADV4400DAA6CD will be stamped on the 89W unit, ADA4400DAA6CD on the 110.
Bull Dog
1,985
The 110w unit IIRC is rates for up to 72 deg C and the 89w one was rated for up to 65 deg C. That was the only difference I could find.
Synomenon
10,547
The 110w unit's temps. are 49-65°C
The 89w unit's temps. are 49-71°C
So the 89w unit's max temp. is higher. That's the only difference I see besides their thermal power.
http://www.amdcompare.com/us-en/desktop...px?opn=ADA4400DAA6CD&opn=ADV4400DAA6CD
Oh and in case anyone wants to know, the model Newegg is selling is the 110w model.
djnsmith7
2,612
Same with Fry's...Picked up mine last night...
