How to take better shots of falling water?
GoingUp
16,720
Anubis
78,712
427
tbqhwy.com
to get rid of the shadow you can either flash it from the side do there is no shadow, use a 2nd flash to blow out the back so it wont matter or if its possiable get some blash cloth that eats light and set it far anough back so that the light wont make a shadow from a direct flash
GoingUp
16,720
Thanks for the ideas. I'll have to change the direction I'm shooting from so I can have a darker background further back. What color background do you recommend for water?
Anubis
78,712
427
tbqhwy.com
really depends on what kind of shot you are going for, normally someting lighter is used as it wont show up well on black
ive seen lots of whites and blues used for backgrounds on water shots
corkyg
Elite Member | Peripherals
27,370
239
Change the angle of the shot. Use fast shutter speed and wide open lens to create a shallow DOF and blur out the background - i.e., "bokeh."
corkyg
27,370
239
I forgot to add, don't use a flash. To illustrate:
Drip
corkyg
27,370
239
Here in Arizona with a belnd of CAP water, that is a never ending problem. As long as they work . . . :)
