How To How to take a running screenshot on android mobile
fgxvcdsm
17
Hi,
How is it possible to take a long screenshot or a running screenshot on android versions lower than 5.
W/o pressing power and volume down buttons at the same time.
Thanks.
WelshBloke
32,877
11,019
Hi,
W/o ptessing power and volume down buttons at the same time.
Thanks.
Depends entirely on the phone.
fgxvcdsm
17
Are there ways to take running screenshots which do not depend on the type of mobile?
balloonshark
7,061
3,544
But it only work on android 11 and up.
Sorry, I missed the lower than android 5 part.
If you have a PC you may be able to use ADB but it's not simple. These articles are old so maybe something has changed.
