How to switch audio from MB and GPU?
techmanc
1,212
7
How can I switch between my on board MB audio system and my Nvidia to play thorough a Bluetooth devices?
I been trying to get my Bluetooth headphones working and it not working
This method be great to hook up some Bluetooth speakers as well TIA?
Iron Woode
31,252
12,777
I have no experience with BT, but I would imagine you need to go into Playback Devices and setup the output needed.
techmanc
1,212
7
This just changes the device output and one of those devices is my BT Speakers or headphones.
Valantar
1,792
508
Yes, and..? You select the device you want to emit sound, it starts emitting sound. Done. Make sure they're paired with your PC first, of course. If you're in W8/10, that's in the "connect" menu. You can't output sound via BT from neither a sound card (integrated or otherwise) or a GPU, as neither of those have BT transmitters. The receiving BT audio device (speaker, headphones, whatever) steps in for decoding duties, leaving everything but the CPU and the BT transmitter out of the loop. As such, the BT device appears as a separate playback device in your menu.
It's worth mentioning that most BT audio solutions have significant - and very noticeable - lag, and don't really work well for most PC use. Watching videos, playing games, whatever you do, having noticeable audio lag is a bummer. Unless your PC supports APTx (which I've never seen in a PC), you're stuck with USB wireless audio or wires.
If you're running a new build of W10, you can select your output device directly from the volume control pop-up by the taskbar. Just click its name, and a menu will appear. If you're using W7, getting BT audio working on that is a hassle like no other, and usually requires third-party codecs and drivers to work, and possibly specific BT dongles. Not worth the hassle.
Reactions: techmanc
techmanc
1,212
7
I use Windows 10 Pro and these BT Headphones with a mic have been sounding great so far with video playback no lag noticed and tested with limited gaming atm but these will be used for gaming playing WoW and DOOM plus a lot of other games soon.
So I see that it will only play BT directly which is a shame as my new Gigabyte MB has some nice options which I now am playing through my HDTV. I am posting the MB link and what speakers will go good with the advanced setup capabilities of the MB?
MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128835
Headphones with mic
http://flash.newegg.com/product/9SIA7XD4JT4968
