How to stop flash from running in the background/startup?
13,802
Flash seems to somehow embed itself right in the PC now it seems. I rebooted and got a notice to update (AGAIN! They ALWAYS update, WTF?). I hate having unneeded programs in my startup. I've even seen it pop up randomly while booted up, so there must be some kind of hidden service that runs or something. Any way to stop this crap? Seems everyone is going this route now :/ Google does it too, Java does it. It's madness.
Crusty
12,684
I would rather Adobe alert me as soon as possible that flash has an update to fix a bug/hole in it. Not keeping flash up to date is a good way to get infected.
13,802
Yeah but they push out updates like multiple times a day, enough is enough. I'll do it at my own leisure once a month or w/e. updating this often is ridiculous. If they really have that many security holes they are doing something wrong.
Modelworks
16,240
7
Rename the updater app. I did that with adobe products because it was annoying. It is either in program files or in the appdata folders don't recall which.
MrChad
13,507
You are exaggerating; they certainly do not push out multiple updates per day. If you are receiving multiple notifications after updating, the updates are not likely being installed. Furthermore, browser plug-ins are one of the most common sources of security issues when browsing the web; it's a good idea to update your plug-ins early and often.
How to disable auto-update notification in Flash Player
WelshBloke
33,092
11,272
The fastest I'm able to set it to get updates is ever 7 days, so yeah, a bit of an exaggeration there. :D
13,802
Thanks I set it to every 60 days. That's more like it. I was going to disable it completely but every 60 days is reasonable.
nsafreak
7,093
So you don't mind potentially being vulnerable to the next flash hole for 59 days?
It's people like the op that I really don't understand. It's not like it takes that much time to do the update unless you have a positively ancient machine. And not updating for 60 days is just asking to get nailed. Personally I have my updates set to check once a day for various programs, Windows included, at around 3 am and it's never affected me.
wiin
937
1. Manage add-ons in IE Tools
2. disable Run ActiveX Control and Plug-ins in Internet Options
3. disable Active Scripting in Internet Options
I enable 2 and 3 as needed. Youtube for example require 2 and 3 enabled.
13,802
It's not the actual updates that are the problem, it's the fact of getting bothered multiple times a day by all sorts of programs. Gets old fast. AVs (I can understand though they should do it in the background which most do), Flash, Adobe Reader, other misc apps, the list goes on. Every single day. That's a lot of rebooting (most apps require a reboot). Are programmers this incompetent that they can't get their program secure after a few patches? They have to patch every day and STILL don't fix the security flaws, or create new ones? I don't even get how something like PDF reader can have a security flaw. The program has nothing in it that could or should allow execution of any type of code, it's simply to display a static document.
Crusty
12,684
What kind of fantasy world do you live in?! The only reason it is asking you multiple times per day is because you refuse to install the update. I can't tell you the last time I had an update done because I don't notice them. Firefox opens up and says I need to update such and such... click a few buttons restart Firefox and I'm good to go. This is NOT because they are releasing updates several times a day... LOL
Nothinman
30,672
Please, let us all know when your 100% bug free PDF reader is available.
Snapster
3,916
But you do have to consider the flip side. Not everyone leaves their pc on 24/7 to update when they are sleeping. Nevermind having say apple updater, adobe updater, AV updater, bt updater x however many apps which may have an updater running in the background.
Whilst this shouldn't really pose a problem, many of the updater's are poorly coded with inefficient wait cycles running too frequently and will also run as soon as you turn your pc on. It's a compounding effect that is tiring, not the individual one.
ITGuy2000
There is some trash in this thread!
If the guy wants to disable it (as do I), then he's got every right to do so.
The less software you run (whether they are updaters or otherwise) the less security issues you will have as you will have reduced your "attack area"; in some cases substantially.
Don't forget the golden rule of security: if it isn't running it can't be exploited. If an updater is running in the background, it is a possible avenue of attack in its own right.
It is also rather interesting to see that Macromedia (now Adobe) saw fit to install Flash into C:\WINDOWS\system32\Macromed and not into Program Files like everyone else. It also says a lot about how their view their customers - with contempt.
I've currently set folder permissions to DENY on this folder, which has killed the FireFox plug-in, but until I find the updater, I don't care.
If I do locate it, I will be sure to post back.
corkyg
Elite Member | Peripherals
27,370
240
Agree wholly with ITGuy2000. Flash is becoming increasingly annoying - a new channel for spurious unwanted audio/video spam.
It is very easy to turn Flash off completely. In IE8, go to Tools, then Manage Add-Ons. look for Adobe and Shockwave Flash Object. Highlight it and click the DISABLE radio button down below. It can be turned on just as easily. When disabled, the radio button changes to ENABLE.
Now I know the source of all the .SWF files that have recently been stuffed into my Temporary Internet Files. And, they have the nerve to make them "access denied."
Nothinman
30,672
I just prefer Flash Block, I don't have to see them most of the time but I can just click on object if I really want that specific one to run. Turning the plugin on/off is just too much hassle to work daily.
corkyg
27,370
240
Disable answers Red Squirrel's initial post. Flash Block is not available in IE. It's no hassle just to keep it disabled - so far in the last three days, I've found no reason to enable it. :)
Nothinman
30,672
The thread's so old I didn't even go back and re-read the OP. =)
