This is a lot more complicated than I thought it would be. I've got two computers, a laptop and a desktop, each independently connected to the net through a linksys wireless router. Due to limitations in my house, I can't use the 4 port switch in the router because it's about 60 feet away.
What I want to do: keep the independent wireless connections as they are between these computers, but when I dock my laptop, use the wired connection between these computers for transferring large amounts of files (using a 100mbps connection, but eventually a gigabit.)
So I bought a crossover cable, thinking that would do the trick, to connect each directly together. But both computers always say although the wired LAN is detected, it has limited or no connectivity. File transfer times show that transfers are going through the wireless, which is 2-3 times slower than wired. I tried plugging each computer into a spare dsl router that has a 4 port switch, and got great transfer speeds.
Both computers are running xp pro, setup through the network setup wizard in an MSHOME network.
How can I achieve my objectives (to get a wired LAN going, and have file transfers go through it instead of the wireless?) Note: I still want to be able to access the net using the wireless cards while I'm transferring)
Complicating the situation, there is a 2nd laptop that I would still like to have capable of accessing the network regardless whether these two computers are talking wirelessly or wired.
