Hello all,
I recently purchased a lot of car electronics that I plan to sell at a flea market.
I need to test all of the equipment to insure it all works.
How do I create a setup to test the RECEIVER + AMP + SUB + OTHER SPEAKERS?
Right now I test the RECEIVERS with a 12v lawnmower battery. It's perfect. However, since I started buying amps, subs, etc... I need to also test those.
How do I wire up a system in the home that is affordable and allows me to connect everything up as if it was in a car?
I have wiring kits and a test board where I can quickly swap out speakers, subs, amps, head units, just need to wire it all correctly before I throw anything on there and blow something up, costing me $$$.
I'd like the setup to run on constant power from my 110v socket, so I imagine I'll need a 110v to 12v converter that then connects to the car battery... and.... yea...
Help plz? 🙂 Thanks all!
