How to set Time Warner remote to control volume on the cablebox?
mercanucaribe
Banned
Oct 20, 2004
9,763
The only way to change the volume is on the cablebox. Since I'm using a monitor's component in, and running sound through the computers line in, I can't change volume without getting up. The tech support guy told me how to program the remote to do it, but it didn't make any difference.
mercanucaribe
Banned
Oct 20, 2004
9,763
Originally posted by: spidey07
You should be able to enable variable output in the service menu.
It's enabled, but you can only change volume using the buttons on the box.
I need to clarify.. the problem is that the remote tries to change TV volume when you press the volume buttons. I need to change that setting on the remote.
mercanucaribe
Banned
Oct 20, 2004
9,763
D'oh! I found it. I had to select cable, then on the remote go into programming mode and enter "933" and then volume -.
