P puck Member Nov 30, 2001 123 0 0 May 21, 2002 #1 Does Win2kPro come with a utility to send a message to another win2k machine on a LAN? Sort of like "instant messages" over the internet?
D DnetMHZ Diamond Member Apr 10, 2001 9,826 1 81 May 21, 2002 #2 Yes.. it is called net send go to a command prompt and type net send /? this will give you the syntax good luck DnetMHZ
P puck Member Nov 30, 2001 123 0 0 May 21, 2002 #3 Cool, thanks. Command prompt the only way? No window-based utility?
O owensdj Golden Member Jul 14, 2000 1,711 6 81 May 21, 2002 #4 puck, there are free 3rd party graphical apps that can do that LAN messaging thing. Try searching the downloads at CNET.COM
