U UCBPride Senior member Feb 20, 2001 383 0 0 Sep 1, 2001 #1 other than in the bios, how the heck can i see what the temp of my cpu is???
M Mark0999 Senior member Jul 6, 2001 852 0 0 Sep 1, 2001 #4 It's in the bios -- hardware monitoring (I think). Otherwise... go to tweakfiles.com and get MBProbe.
R RagingGuardian Golden Member Aug 22, 2000 1,330 0 0 Sep 1, 2001 #5 Search for Motherboard Monitor and use that to check your system temparature. I would post the link but I'm way too lazy to go finding the site.
B bocamojo Senior member Aug 24, 2001 818 0 0 Sep 1, 2001 #6 Here's the link for Motherboard Monitor (freeware): http://www.tweakfiles.com/diagnostic/motherboardmonitor.html
I Insane3D Elite Member May 24, 2000 19,446 0 0 Sep 1, 2001 #7 "Search for Motherboard Monitor and use that to check your system temparature. I would post the link but I'm way too lazy to go finding the site. " "Here's the link for Motherboard Monitor (freeware): http://www.tweakfiles.com/diagnostic/motherboardmonitor.html " As of now, Motherboard Monitor 5 does not work correctly with the Sis735. To my knowledge, MBProbe is the only progra mthat works at the moment.
