My house has two stories, plus a basement. I want to put an antenna up in my attic. I have never done any sort of wiring, so please speak to me as if I were a kindergartener.
I have a powered antenna attached to my TV in the living room on the first floor. The signal is constantly dropping out. I have cheapo rabbit ears attached to the curtain valence in my second floor bedroom. The bedroom TV gets great reception for all local channels. This has proven to me that I really don't need much of an antenna in order to get all the local digital channels, as long as the antenna is high enough.
I want to put a TV in the basement also.
1. What kind of antenna is appropriate for an attic? Do I need to worry about any electrical issues (e.g. static electricity) if I just stick a small cheap unpowered antenna up there?
2. How do I run cable from the antenna to the three different floors of the house? I want the wiring to be hidden in the walls.
3. What kind of cable should I use? I've read that I should use RG-6 rated for in-wall use. Is that correct? Where can I find it?
Thanks in advance for any advice.
